Alphacool Core Geforce RTX 5080 Reference with backplate
- Article no.: 10248
- EAN: 4250197102483
- Weight: 1,204 kg
- Inno3D GeForce RTX™ 5070 Ti iCHILL X3 (C507T3-16D7X-176069H)
- Inno3D GeForce RTX™ 5070 Ti X3 (N507T3-16D7-176068N)
- Inno3D GeForce RTX™ 5070 Ti X3 OC (N507T3-16D7X-176068N)
- Inno3D GeForce RTX™ 5070 Ti X3 OC WHITE (N507T3-16D7X-176068W)
- MSI GeForce RTX™ 5070 Ti 16G INSPIRE 3X OC (MS-V531 Ver:3.0)
- MSI GeForce RTX™ 5070 Ti 16G SHADOW 3X OC
- MSI GeForce RTX™ 5070 Ti 16G VENTUS 3X OC (V531-092R)
- Inno3D GeForce RTX™ 5080 iChill Frostbite (C50803-16D7X-1760FB)
- Inno3D GeForce RTX™ 5080 iChill X3 (C50803-16D7X-176069H)
- Inno3D GeForce RTX™ 5080 X3 (N50803-16D7-176068N)
- Inno3D GeForce RTX™ 5080 X3 GAMING OC (G50803-16D7X-17603930)
- Inno3D GeForce RTX™ 5080 X3 OC (N50803-16D7X-17603930)
- Inno3D GeForce RTX™ 5080 X3 OC White (N50803-16D7X-17605211)
- MSI GeForce RTX™ 5080 16G INSPIRE 3X OC (MS-V531 Ver:3.0)
- MSI GeForce RTX™ 5080 16G SHADOW 3X OC (G5080-16S3C)
- MSI GeForce RTX™ 5080 16G VENTUS 3X OC (V531-095R)
- MSI GeForce RTX™ 5080 16G VENTUS 3X OC Plus (V531-001R)
| Technical data cooler | |
| Dimensions total (L x W x H) | 160 x 124,07 x 34,19mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 7 |
| Color | transparent |
| Dimensions (L x W x H) | 160 x 95,36 x 6mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
