Alphacool Eisblock Aurora Acryl GPX-N RTX 3070 with Backplate (Reference)
- Article no.: 11934
- EAN: 4250197119344
- Weight: 1,139 kg
Important note: The Reference cooler is not compatible with Nvidia's Founders Edition.
More performance!
During the development of the Eisblock Aurora Acryl GPX graphics card water cooler, emphasis was naturally placed on increasing performance. First, the cooler was brought closer to the individual components by reducing the thickness of the heat conducting pads. Next, the chrome-plated copper block was also made thinner. Step 3 involves the constant optimisation of the water flow within the cooler. The result: All important components such as voltage converters and RAM are cooled much better and more effectively by the water and the cooling performance increases significantly.
Brilliant design!
Copper or aluminium?
Alphacool uses only copper for all water-bearing parts. Copper has almost twice the thermal conductivity of aluminum and is therefore clearly the better choice of material for water cooling. The cooler is made entirely of chrome-plated copper. A chrome plating is much harder than a nickel plating and therefore less sensitive to acids, scratches and damage. It completely eliminates the risk of chipping nickel plating. Additionally, chrome plating looks much more homogeneous and provides a shine that cannot be achieved by nickel plating.
Other special features
- Inno3D GeForce RTX 3070 iCHILL X3, 8GB GDDR6 (C30703-08D6X-1710VA38)
- Inno3D GeForce RTX 3070 iCHILL X4, 8GB GDDR6 (C30704-08D6X-1710VA35)
- Inno3D GeForce RTX 3070 Twin X2 OC, 8GB GDDR6 (N30702-08D6X-1710VA32L)
- Inno3D GeForce RTX 3070 Twin X2, 8GB GDDR6 (N30702-08D6-1710VA32L)
| Technical data cooler | |
| L x W x H | 239 x 122 x 25mm |
| Threads | 4 x G1/4 |
| Thickness cooling fins | 0,6 mm |
| Number of digital aRGB LEDs | 11 |
| L x W x H | 239 x 97 x 6mm |
| Material | aluminium |
| Color | black |
Delivery date: in 5 - 6 weeks
