Alphacool Core Thermal Pad Soft 9W/mk 100x100x1,5mm
  • 13417
  • 4250197134170
  • 0,064 kg
€16.48 * €29.98 * (45.03% Saved)
Content: 100 cm² (€0.16 * / 1 cm²)
€4.28*
€69.98*
13416 Alphacool Core Thermal Pad Soft 9W/mk 100x100x1mm
€11.78*
13422 Alphacool Core Thermal Pad Soft 9W/mk 40x40x1,5mm
€5.58*
13427 Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
€6.99*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)100 x 100 x 1,5mm
Thermal Conductivity (ASTM D5470)9.0 W/mK (±10%)
Hardness (ASTM D2240)50 (Shore 00) (±15)
Working temperature-50 to ~180°C
Volume Resistance (ASTM D257)1×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)≥8 KV/mm
Density (ASTM D792)3.2 g/cm³ (±10%)
Flame Rating (UL 94)V-0
Colorpink
Elongation (ASTM D412)40%
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
49%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.19 * / 1 cm²)
€18.78 * €36.99 *
46%
Content 100 cm² (€0.12 * / 1 cm²)
€11.78 * €21.98 *
44%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x3mm
Content 100 cm² (€0.28 * / 1 cm²)
€27.98 * €49.98 *
50%
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 * €18.98 *
43%
€3.97 * €6.99 *
32%
Alphacool Apex Thermal Pad Soft 18W/mk 120x20x1,5mm
Content 24 cm² (€1.41 * / 1 cm²)
€33.88 * €49.98 *
41%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.48 * / 1 cm²)
€7.68 * €12.98 *
48%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88 * €24.98 *
€1.68 *
€34.98 *
44%
WÄM Alphacool Apex Soft Wärmeleitpad 14W/mk 2x 120x20x1mm
Alphacool Apex Soft thermal pad 14W/mk 2x 120x20x1mm
Content 48 cm² (€0.53 * / 1 cm²)
€25.28 * €44.98 *
20%
€3.97 * €4.97 *
Alphacool M3 spacer 34mm
€3.98 *
6%
€16.98 * €17.98 *
86%
KAB Alphacool Y-Kabel RGBW 5pol auf 3x 5pol inkl. Stecker - Schwarz 60cm EOL
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 60cm
Content 60 Zentimeter (€1.65 * / 100 Zentimeter)
€0.99 * €6.89 *
Alphacool HardTube 16/13mm 90° acrylic (PMMA) 20/40cm
Content 60 Zentimeter (€21.63 * / 100 Zentimeter)
€4.48 *
Alphacool NexXxos Radiator Fan Mounting Screw M3 x 37 mm - 4 pieces
€3.98 *
35%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
Content 48 cm² (€0.30 * / 1 cm²)
€14.38 * €21.98 *
