Alphacool Core Thermal Pad Soft 9W/mk 100x100x2mm
  • 13418
  • 4250197134187
  • 0,08 kg
€18.78 * €36.99 * (49.23% Saved)
Content: 100 cm² (€0.19 * / 1 cm²)
€4.28*
€69.98*
13419 Alphacool Core Thermal Pad Soft 9W/mk 100x100x3mm
€27.98*
13423 Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
€6.18*
13427 Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
€6.99*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)100 x 100 x 2mm
Thermal Conductivity (ASTM D5470)9.0 W/mK (±10%)
Hardness (ASTM D2240)50 (Shore 00) (±15)
Working temperature-50 to ~180°C
Volume Resistance (ASTM D257)1×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)≥8 KV/mm
Density (ASTM D792)3.2 g/cm³ (±10%)
Elongation (ASTM D412)40%
Flame Rating (UL 94)V-0
Colorpink
44%
Content 100 cm² (€0.28 * / 1 cm²)
€27.98 * €49.98 *
45%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x1,5mm
€16.48 * €29.98 *
46%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x1mm
Content 100 cm² (€0.12 * / 1 cm²)
€11.78 * €21.98 *
47%
€15.78 * €29.98 *
50%
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 * €18.98 *
43%
€3.97 * €6.99 *
31%
€23.98 * €34.97 *
56%
Alphacool Apex Thermal Pad Soft 18W/mk 100x100x1mm
Content 100 cm² (€0.44 * / 1 cm²)
€43.98 * €99.98 *
41%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.48 * / 1 cm²)
€7.68 * €12.98 *
44%
WÄM Alphacool Apex Soft Wärmeleitpad 14W/mk 2x 120x20x1mm
Alphacool Apex Soft thermal pad 14W/mk 2x 120x20x1mm
Content 48 cm² (€0.53 * / 1 cm²)
€25.28 * €44.98 *
61%
€5.78 * €14.98 *
Alphacool Core double sided adhesive thermal pad 100x100x0.25mm
Content 100 cm² (€0.07 * / 1 cm²)
€6.99 *
32%
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 100x100x1,5mm
Alphacool Apex Thermal Pad Soft 16W/mk 100x100x1,5mm
Content 100 cm² (€0.81 * / 1 cm²)
€81.28 * €119.98 *
41%
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 120x20x1mm
Alphacool Apex Thermal Pad Soft 18W/mk 120x20x1mm
Content 24 cm² (€0.98 * / 1 cm²)
€23.59 * €39.98 *
58%
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 100x100x1,5mm
Alphacool Apex Thermal Pad Soft 18W/mk 100x100x1,5mm
Content 100 cm² (€0.76 * / 1 cm²)
€75.68 * €179.98 *
43%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1mm
Content 24 cm² (€0.24 * / 1 cm²)
€5.68 * €9.98 *
43%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x0,5mm
Content 24 cm² (€0.19 * / 1 cm²)
€4.58 * €7.98 *
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
45%
Content 100 cm² (€0.18 * / 1 cm²)
€17.98 * €32.97 *
€5.28 *
€3.47 *
€2.68 *
€1.89 *
