  • 13406
  • 4250197134064
  • 0,108 kg
€17.98 * €32.97 * (45.47% Saved)
Content: 100 cm² (€0.18 * / 1 cm²)
€4.28*
€69.98*
13404 Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x1,5mm
€11.98*
13414 Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
€5.58*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)100 x 100 x 3mm
Thermal Conductivity (ASTM D5470)6.2 W/mK (±10%)
Hardness (ASTM D412)50 (Shore 00) (±15)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)1×10¹³ Ohm-m
Dielectric Breakdown Voltage (ASTM D149)6 KV/mm (±10%)
Density (ASTM D792)3.1 g/cm³ (±10%)
Elongation (ASTM D412)50%
Flame Rating (UL 94)V-0
Colorblue
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
48%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88 * €24.98 *
61%
€5.78 * €14.98 *
47%
€15.78 * €29.98 *
38%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
31%
€23.98 * €34.97 *
WÄM Alphacool Apex Thermal Putty X1 50g
Content 50 Gramm (€939.60 * / 1000 Gramm)
€46.98 *
€3.78 *
46%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x1mm
Content 100 cm² (€0.12 * / 1 cm²)
€11.78 * €21.98 *
€2.48 *
43%
€3.97 * €6.99 *
32%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x1mm PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x1mm
Content 100 cm² (€0.55 * / 1 cm²)
€54.78 * €79.98 *
GHE Alphacool ES 19" Open Frame Serverrack 12HE Verstellbare Tiefe
Alphacool ES 19" Open Frame Serverrack 12U Adjustable Depth
€229.98 * €309.38 *
Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 15cm white
Content 15 Zentimeter (€26.47 * / 100 Zentimeter)
€3.97 *
€4.97 *
€2.58 *
WAC Alphacool Core 1 Silver
42%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
Content 24 cm² (€0.29 * / 1 cm²)
€6.99 * €11.98 *
Alphacool Core Thermal Pad Soft 9W/mk 40x40x1,5mm
Content 16 cm² (€0.35 * / 1 cm²)
€5.58 * €7.98 *
49%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.19 * / 1 cm²)
€18.78 * €36.99 *
€6.99 *
€69.98 *
