Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 15cm white
  • 18728
  • 4250197187282
  • 0,026 kg
€3.97 *
Content: 15 Zentimeter (€26.47 * / 100 Zentimeter)
€5.98*
€12.98*
€16.99*
€15.98*
€18.98*
Alphacool's 4-pin to 4x 4-pin Y-splitter cable is a high-quality solution to easily connect and... more
Alphacool's 4-pin to 4x 4-pin Y-splitter cable is a high-quality solution to easily connect and control multiple PWM fans from the motherboard without the need for a separate fan control HUB. This cable is ideal for expanding the limited number of motherboard slots for these types of fans. With high-quality sleeving, the cable offers added protection, stability, and longer lifetime. The cable is offered in various lengths.
Length15cm
Connections1x 4-Pin to 4x 4-Pin PWM
MaterialPlastic, sleeved
Colorwhite
€1.79 *
€2.28 *
Delivery date: in 5 - 6 weeks
€3.18 *
Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 30cm white
Content 30 Zentimeter (€15.60 * / 100 Zentimeter)
€4.68 *
€2.58 *
€2.58 *
€3.78 *
Alphacool fan cable 4-pin to 4-pin extension PWM 15cm white
Content 15 Zentimeter (€14.60 * / 100 Zentimeter)
€2.19 *
€4.97 *
€2.98 *
45%
Content 100 cm² (€0.18 * / 1 cm²)
€17.98 * €32.97 *
€6.99 *
€5.68 *
€2.78 *
€1.68 *
€3.47 *
€1.98 *
€34.98 *
€33.98 *
