Alphacool thermal pad for NexXxoS GPX 3W/mk 15x15x3mm yellow marked PE Bag (24 pieces)
  • 12195
  • 4250197121958
  • 0,044 kg
€6.29 *
Content: 54 cm² (€0.12 * / 1 cm²)
Area of application:
  • Graphics card ram cooler
  • Mainboard voltage converter
  • North and/or Southbridge thanks to the excellent thermal conductivity
  • Color: grey
  • Dimensions (L x W x H): 15 x 15 x 3mm
  • Thermal conductivity: 3W/mk
  • electrically non-conductive
Scope of delivery
  • 24x Alphacool thermal pad for NexXxoS GPX
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
61%
€5.78 * €14.98 *
€1.48 *
35%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
Content 48 cm² (€0.30 * / 1 cm²)
€14.38 * €21.98 *
Alphacool Silver Grease 0.5g
€1.19 *
24%
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
Content 16 cm² (€0.24 * / 1 cm²)
€3.78 * €4.97 *
48%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88 * €24.98 *
37%
Alphacool Eisschicht Ultra Soft thermal pad 3W/mk 100x100x1,5mm
€15.78 * €24.98 *
€1.89 *
47%
€15.78 * €29.98 *
43%
€3.97 * €6.99 *
62%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 100x100x0,5mm
Content 100 cm² (€0.05 * / 1 cm²)
€4.88 * €12.98 *
6%
€16.98 * €17.98 *
Alphacool Eisblock Aurora mounting screws and springs M2x6mm
Content 10 Stück (€0.30 * / 1 Stück)
€2.98 *
