Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
  • 13407
  • 4250197134071
  • 0,016 kg
€3.78 * €4.97 * (23.94% Saved)
Content: 16 cm² (€0.24 * / 1 cm²)
€4.28*
€69.98*
13402 Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x0,5mm
€6.88*
13409 Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1,5mm
€4.68*
13412 Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x0,5mm
€4.18*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)40 x 40 x 0,5mm
Thermal Conductivity (ASTM D5470)6.2 W/mK (±10%)
Hardness (ASTM D412)50 (Shore 00) (±15)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)1×10¹³ Ohm-m
Dielectric Breakdown Voltage (ASTM D149)6 KV/mm (±10%)
Density (ASTM D792)3.1 g/cm³ (±10%)
Elongation (ASTM D412)50%
Flame Rating (UL 94)V-0
Colorblue
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
Alphacool Silver Grease 0.5g
€1.19 *
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1mm
Content 16 cm² (€0.22 * / 1 cm²)
€3.58 * €4.97 *
37%
Alphacool Eisschicht Ultra Soft thermal pad 3W/mk 100x100x1,5mm
€15.78 * €24.98 *
€1.89 *
47%
€15.78 * €29.98 *
€6.49 * €8.98 *
6%
€16.98 * €17.98 *
Alphacool Silicon Bending Insert 150cm for ID 1/2" / 13mm HardTubes - Blue
Content 150 Zentimeter (€11.32 * / 100 Zentimeter)
