Alphacool Aurora HardTube LED Ring 16mm Deep Black - Digital RGB
  • 15367
  • 4250197153676
  • 0,018 kg
€11.98 *
S13 Alphacool HardTube 13/10mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€20.98*
S13 Alphacool HardTube 13/10mm borosilicate glass 60cm
€11.88*
€25.98*
S16 Alphacool Ice Tube 16/13mm PETG HardTube 80cm - Set of 4 (320cm)
€26.98*
AGZ Alphacool Aurora LED Ring 60mm - Digital RGB
€24.48*
WACZ Alphacool Aurora XPX Digital RGB Frame - Chrome EOL
€6.99*
The new Aurora HardTube LED rings with addressable RGB connection offer you the best modding... more
The new Aurora HardTube LED rings with addressable RGB connection offer you the best modding options to control and stage your system like a pro.
Optics at its finest
The new aRGB technology gives you the option to illuminate your entire system with different color modes. This makes your gaming system a real eye-catcher at any LAN party or simply at home.
Alphacool offers compatibility
With the new LED rings from Alphacool you can illuminate all hard tubes or hoses with an outer diameter of 13mm or 16mm and thus equip a variety of different systems, just as you want. The power connection is made via a 3-pin JST connector. For direct connection to a mainboard, a 3-pin JST to 3-pin aRGB adapter is required.
Technical data:
  • Inner diameter: 16 mm
  • Outer diameter: 25 mm
  • Case length: 20 mm
  • LEDs: Digital addressable RGB LEDs
  • Connector: 3-pin
  • Cable length: 75 cm
€1.48 *
€28.98 *
€39.98 *
€28.98 *
€38.98 *
€6.99 *
Alphacool HardTube 16/13mm 90° acrylic (PMMA) 20/40cm
Content 60 Zentimeter (€21.63 * / 100 Zentimeter)
€26.98 *
Alphacool extension JST aRGB 3-pin to 3-pin 15cm
Content 15 Zentimeter (€8.60 * / 100 Zentimeter)
€1.29 *
€1.98 *
Alphacool Silicon Bending Insert 150cm for ID 1/2" / 13mm HardTubes - Blue
Content 150 Zentimeter (€11.32 * / 100 Zentimeter)
