Alphacool MCX 2x distributor with 1m 5/3mm hose
  • 13041
  • 4250197130417
  • 0,01 kg
€36.98*
13040 Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3080/3090 Suprim X
€29.98*
WAGZ Alphacool MCX Cap - Black Set of 10
€3.18*
S5 hose PVC 5/3mm clear sold by the meter
€1.19*
Flexibility and design with optimal performance! The Alphacool MCX 2x distributor made of acetal... more
Flexibility and design with optimal performance! The Alphacool MCX 2x distributor made of acetal offers various areas of application.
It opens up the possibility to easily integrate Alphacool's active backplates or MCX water coolers into the water circuit. This allows e.g. RAM devices and voltage converters on graphics cards to be cooled more efficiently. The integration of the MCX 2x distributor into the water circuit is uncomplicated via 2 G1/4" connections with internal thread. Alphacool's connections from the Eiszapfen series are recommended here. A transparent 5/3mm PVC hose is included in the delivery. With a length of 1m, the hose offers sufficient leeway for a flexible installation of the distributor.
L x W x H distributor30 x 29 x 18 mm
Material distributoracetal
Length hose1 m
Hose size5/3mm
Material hosePVC
Connections2x G 1/4 inner thread | 2x hose nozzles 3 mm screwed in
Max. Thread length G 1/4 Connections5.5 mm
Max working temperature60 °C
Pressure tested (without clamps)3.2 bar
Pressure tested (with clamps)5.2 bar
Weight28 g
Content 10 Stück (€0.32 * / 1 Stück)
€3.18 *
WAO Alphacool MCX one
Alphacool MCX one
€1.19 *
€3.18 *
Alphacool MCX one
€6.49 * €8.98 *
WAO Alphacool MCX ram
Alphacool MCX ram
