Alphacool MCX ram
- Article no.: 12272
- EAN: 4250197122726
- Weight: 0,015 kg
*1The MCX one miniature waterblock offers a multitude of possibilities. It allows most efficient cooling of e.g. RAM modules on graphics cards or VRM modules and can be mounted easily. If the criteria is flexibility and design in combination with optimal performance, the MCX one is an adequate solution. Your investment is also long-term as the MCX components can be used again.
| Technical data | |
| Dimensions (L x W x H) | 15x15x5mm |
| Material | Nickel-plated copper |
| Tube size | 3mm inner diameter |
| Pressure tested (without clamps) | 3 bar |
| Pressure tested (with clamps) | 8 bar |
| Color | silver |
