Alphacool ES Socket 4677 CPU Carrier E1A
- Article no.: 13835
- EAN: 4250197138352
- Weight: 0,047 kg
€10.98 *
The Alphacool ES Carrier enables the mounting of the ES Jet/Stream CPU Cooler on the... more
The Alphacool ES Carrier enables the mounting of the ES Jet/Stream CPU Cooler on the corresponding processor. (Intel: Socket LGA 4677)
Intel: LGA 4677
| Technical data | |
| Dimensions (L x W x H) | 118,60 x 75,50 x 15,80 mm |
| Material | Plastic |
| Weight | 10g |
| Color | black |
Alphacool NexXxoS XP³ screw set socket 2011 4 pieces - black
Content
4 Stück
(€1.00 * / 1 Stück)
€3.98
Content
6 Stück
(€5.33 * / 1 Stück)
€31.98
Content
330 Zentimeter
(€6.05 * / 100 Zentimeter)
€19.98
Content
1 Gramm
(€6,990.00 * / 1000 Gramm)
€6.99
Alphacool Eiszapfen 13mm HardTube compression fitting 90° rotatable G1/4 for Acryl/Brass tubes - 4pcs Set Deep Black
Content
4 Stück
(€9.00 * / 1 Stück)
€35.98
69%
Alphacool Eisblock Aurora Acryl GPX-N RTX 3090TI Founders Edition with Backplate
€49.99
€159.98
Content
3.5 Gramm
(€1,854.29 * / 1000 Gramm)
€6.49
€8.98
Alphacool ES flow and temperature indicator "HighFlow" with RPM-Signal
€41.98
Content
6 Stück
(€3.16 * / 1 Stück)
€18.98
Alphacool NexXxos fan mounting screw M3 x 30 mm - 4 pieces
Content
4 Stück
(€1.12 * / 1 Stück)
€4.48
