Alphacool NexXxoS XP Holder S.1155/1156
  • 12693
  • 4250197126939
  • 0,038 kg
€12.29 *
This bracket is intended for conversion, extension or as a spare part for the popular Alphacool... more
This bracket is intended for conversion, extension or as a spare part for the popular Alphacool NexXxos XP (light), X2 up to Plus Highflow.
Socket type 1156
1x bracket
Note: If you use this holder to replace the old one, you can reuse the mounting material. Otherwise, we recommend bolt screw, M4 thread, 94504. Mounting material can be retaining clips (item number: 16079) or a universal accessory pack (e.g. item number: 16081 or 16116).
Attention: If the retaining clip is in the way of the bracket for the CPU as in the example picture, bridging it with washers, e.g. using article number: 94523, will help.
