Alphacool NexXxoS XP³ screw set - Black
- Article no.: 12157
- EAN: 4250197121576
- Weight: 0,057 kg
*1Replacement screw set for the Alphacool NexXxoS XP³ CPU water cooler, but also compatible with other CPU coolers. This mounting set is characterized by its beautiful black color and slim design.
Technical data:
Knurled nut internal thread: M4,
Dimensions knurled nut (HxD): 8x12mm
Spring length: 15mm, color black
Screws: 4x M4x45mm
Weight: 38g
1x assembly screw set, consisting of: hexagon socket wrench, plastic washers, M4 knurled nut high design, springs, screws
