- Article no.: 13009
- EAN: 4250197130097
- Weight: 0,067 kg
- Available: Currently there are 2 available - More is on the way
The Alphacool Subzero Thermal Grease is intended for all users who want to achieve optimum performance with their system. This electrically non-conductive thermal paste suitable for high contact pressures is an excellent choice when performance and ease of application are required.
Application
Subzero Thermal Grease can be optimally applied due to its high viscosity. For perfect application of the thermal paste, a plastic spatula (included in delivery) or a comparable tool should be used.
Properties
Alphacool's Subzero Thermal Grease has a high thermal conductivity, making it one of the best performing thermal pastes on the market. Only thermal pastes made from liquid metal offer better thermal conductivity. Subzero Thermal Grease is delivered in an applicator with a screw cap. The amount of thermal grease is sufficient for several applications and can be stored in the applicator to protect it from drying out. A plastic spatula is included for perfect application of the thermal paste. Subzero Thermal Grease is non-conductive and non-caustic. If a small amount of paste is spilled during application, damage to the hardware is highly unlikely.
| Technical data | |
| Color Appearance | gray |
| Viscosity | 3 000 000 mPa·s |
| Specific Gravity | 2.7 g/cm³ |
| Thermal Resistance (°C·cm²/W) 60 psi | 0.05 |
| Dielectric Constant | 14.5 at 1 MHz |
| Volatile matter (%), 120 °C @96 h | 0.18 |
| Out Gasing (%), 200 °C @96 h | 0.01 |
| Temperature Stability | -50 to 200 °C |
| Shelf Life | 2 years |
| Product Features | easy to work with, non-caustic, anti-oxidation, not easily solidifying |
- Causes serious eye irritation.
- Avoid release to the environment.
- Wear protective gloves/protective clothing/eye protection/face protection.
- IF IN EYES: Rinse cautiously with water for several minutes. Remove contact lenses if present and easy to do – continue rinsing.
- If eye irritation persists get medical advice/attention.
- Dispose of contents/container according to local/national/international regulations.
- Very toxic to aquatic organisms with long lasting effects.
- Collect spillage.
