  • 13008
  • 4250197130080
  • 0,023 kg
€3.97 * €4.97 * (20.12% Saved)
Content: 1 Gramm (€3,970.00 * / 1000 Gramm)
€62.98*
ZSO Alphacool antistatic wrist cuff blue
€4.48*
€6.49*
13009 Alphacool Subzero Thermal grease 20g
€33.97*
€4.28*
The Alphacool Subzero Thermal Grease is intended for all users who want to achieve optimum... more
The Alphacool Subzero Thermal Grease is intended for all users who want to achieve optimum performance with their system. With a thermal conductivity of 16 W/mK, this electrically non-conductive thermal paste suitable for high contact pressures is an excellent choice when performance and ease of application are required.
Application
Subzero 16W/mK Thermal Grease can be optimally applied due to its high viscosity. For perfect application of the thermal paste, a plastic spatula (included in delivery) or a comparable tool should be used.
Properties
Alphacool's Subzero Thermal Grease has a high thermal conductivity of 16 W/mK, making it one of the best performing thermal pastes on the market. Only thermal pastes made from liquid metal offer better thermal conductivity. Subzero Thermal Grease is delivered in an applicator with a screw cap. The amount of thermal grease is sufficient for several applications and can be stored in the applicator to protect it from drying out. A plastic spatula is included for perfect application of the thermal paste. Subzero Thermal Grease is non-conductive and non-caustic. If a small amount of paste is spilled during application, damage to the hardware is highly unlikely.
Color Appearancegray
Viscosity3 000 000 mPa·s
Specific Gravity2.7 g/cm³
Thermal Resistance (°C·cm²/W) 60 psi0.05
Dielectric Constant14.5 at 1 MHz
Volatile matter (%), 120 °C @96 h0.18
Out Gasing (%), 200 °C @96 h0.01
Temperature Stability-50 to 200 °C
Shelf Life2 years
Product Featureseasy to work with, non-caustic, anti-oxidation, not easily solidifying
Safety notes
Warning
  • Causes serious eye irritation.
  • Avoid release to the environment.
  • Wear protective gloves/protective clothing/eye protection/face protection.
  • IF IN EYES: Rinse cautiously with water for several minutes. Remove contact lenses if present and easy to do – continue rinsing.
  • If eye irritation persists get medical advice/attention.
  • Dispose of contents/container according to local/national/international regulations.
  • Collect spillage.
Alphacool Silver Grease 0.5g
€1.19 *
21%
€33.97 * €42.98 *
22%
€46.98 * €59.98 *
Content 50 Gramm (€1,399.60 * / 1000 Gramm)
€69.98 *
61%
€5.78 * €14.98 *
€6.99 *
Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Blue transparent 3m (9.8ft) Retailbox 300cm
€1.89 *
35%
€51.98 * €79.98 *
47%
€15.78 * €29.98 *
€4.97 *
