  • 13098
  • 4250197130981
  • 0,115 kg
€122.97 *
Content: 100 Gramm (€1,229.70 * / 1000 Gramm)
€62.98*
€6.49*
13020 Alphacool Apex Soft Thermal Pad 14W/mk 100x100x1mm
€44.08*
WÄM Alphacool Apex Soft thermal pad 14W/mk 2x 120x20x1mm
€25.28*
€4.28*
The Alphacool Apex Thermal Grease is intended for all users who want to achieve the optimum... more
The Alphacool Apex Thermal Grease is intended for all users who want to achieve the optimum performance with their system. With its thermal conductivity, this electrically non-conductive heat-conducting paste, which is suitable for high contact pressures, is clearly the favorite when performance and easy processing are required.
Application
Properties
Alphacool's Apex Thermal Grease has an extremely high thermal conductivity, making it one of the best performing thermal pastes on the market. Only liquid metal thermal pastes offer better thermal conductivity. The Apex Thermal Grease is delivered in a 100g container with screw cap. The amount of thermal paste is sufficient for several applications and can be stored in the container protected from drying out. In addition, Apex Thermal Grease is non-conductive and non-caustic. If a small amount of paste is spilled during application, damage to the hardware is highly unlikely.
Range of uses
Volatilization Rate (24 H@200 °C)%less than 0.5
Density3.2 g/cm³ (Test method ASTM D792)
Viscosity150-200 × 10³ mPa·s (Test method ASTM D2196)
Continuous Using Temperature (°C)-40 °C to 120 °C
Breakdown Voltage250 V/mil (Test method ASTM D149)
Thermal Impedance0.1 ±0.01 °C in 2/W (Test method ASTM D5470)
Max. working pressure40 psi
Colorgray
Quantity100 g
Safety notes
Warning
  • Rinse gently with water for a few minutes.
  • In case of fire: Do not inhale explosion and fire gases.
Alphacool Silver Grease 0.5g
€1.19 *
20%
€3.97 * €4.97 *
21%
€33.97 * €42.98 *
22%
€46.98 * €59.98 *
€34.98 *
€1.89 *
Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 30cm white
Content 30 Zentimeter (€15.60 * / 100 Zentimeter)
€4.68 *
€3.18 *
€2.48 *
14%
AGB Alphacool Rise Flat Reservoir DDC EOL
€89.98 * €104.98 *
Alphacool HardTube 13mm OD 90° Brass 20/40cm Deep Black
Alphacool HardTube 13mm OD Brass Deep Black 40cm
34%
Alphacool Ice Cyclone Aurora LUX Digital RGB - Kit of 3 (120x120x25mm)
Content 3 Stück (€8.66 * / 1 Stück)
€25.98 * €39.25 *
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
33%
WÄM Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 100x100x0,5mm PHT EOL
Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x0,5mm
Content 100 cm² (€0.05 * / 1 cm²)
€5.38 * €7.98 *
Alphacool GPU RAM Copper Heatsinks 6.5x6.5mm - 10 pcs.
Content 10 Stück (€1.00 * / 1 Stück)
Delivery date: in 5 - 6 weeks
€26.98 *
41%
Phobya VGA Power Connector 6+2Pin plug incl. 8 pins - 2 pieces Black
Content 2 Stück (€1.44 * / 1 Stück)
€2.87 *
ANZ Knickschutzfeder einzeln 16mm (100mm Lang) - black nickel PHT EOL
kink protection spring single 16mm (100mm long) - black nickel
Content 10 Zentimeter (€0.22 * / 1 Zentimeter)
€2.19 *
