Alphacool Apex Soft Thermal Pad 14W/mk 100x100x1mm
  • 13020
  • 4250197130202
  • 0,056 kg
€44.08 * €69.98 * (37.01% Saved)
Content: 100 cm² (€0.44 * / 1 cm²)
€62.98*
ZSO Alphacool antistatic wrist cuff blue
€4.48*
€6.49*
WÄM Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
€9.58*
WÄM Alphacool Apex Soft thermal pad 14W/mk 2x 120x20x1mm
€25.28*
The Apex Soft thermal pads are Alphacool’s high-end solution in the field of thermal interface... more
The Apex Soft thermal pads are Alphacool’s high-end solution in the field of thermal interface materials. Thanks to their outstanding properties, they can almost be compared to thermal paste. Apex Soft thermal pads conform much better to components, resulting in a significant improvement in cooling performance.
The material used in Apex Soft pads behaves similarly to thermal paste. Its consistency prevents higher-standing components, such as voltage regulators or VRAMs, from being subjected to excessive mounting pressure from the cooler — which, in the worst case, could lead to PCB bending. Apex Soft pads fill surface irregularities more effectively and conform more closely to component shapes, which significantly enhances thermal transfer between the cooler and the hardware.
The special material also does not dry out over time. Standard thermal pads often begin to bleed silicone over time, making them hard and drastically reducing their performance. This is not the case with Apex Soft pads. They can be used for much longer periods without a noticeable drop in performance.
When cutting the pads to size, it’s important to leave the protective film on. This allows the pads to be easily cut with scissors — just like cutting paper. The cut edges remain clean and do not fray.
Alphacool’s Apex Soft thermal pads offer significantly better performance than conventional thermal pads in many aspects and are the perfect replacement for old or underperforming pads.
Technical data thermal pad
Dimensions (L x W x H)100 x 100 x 1,0mm
Specific gravity (ASTM D792)3.2 g/cc
Thermal Conductivity14.0 W/mK
Hardness (ASTM D2240)80 Shore OO
Working temperature-40 to +150 °C
Volume Resistance (ASTM D257)1.0x10^11 Ohm-m
Dielectric Breakdown Voltage (ASTM D150)6.8 MHz
Density (ASTM D792)3.6 g/cm³ (±10%)
Dielectric breakdown (ASTM D149)13 kV/mm
Flame Rating (UL 94)V-0
Colorgrey
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
Alphacool ES TPV 8/5 - Tube - Black Matte 3,3m (10ft) Retailbox 330cm
44%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x3mm
Content 100 cm² (€0.28 * / 1 cm²)
€27.98 * €49.98 *
33%
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
Content 24 cm² (€0.20 * / 1 cm²)
€4.68 * €6.99 *
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 120x20x0,5mm
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x0,5mm
Content 24 cm² (€0.17 * / 1 cm²)
€4.18 * €5.99 *
45%
Content 100 cm² (€0.18 * / 1 cm²)
€17.98 * €32.97 *
€1.89 *
50%
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 * €18.98 *
62%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 100x100x0,5mm
Content 100 cm² (€0.05 * / 1 cm²)
€4.88 * €12.98 *
Alphacool Aurora LED Flexible Light - Digital RGB 30cm
Content 30 Zentimeter (€53.27 * / 100 Zentimeter)
€1.78 *
Delivery date: in 2 - 3 weeks
Laing DDC-pump 12V DDC 4.2 PWM
€74.98 * €101.13 *
Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV red 3m (9.8ft) retail box 300cm
