Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
  • 13413
  • 4250197134132
  • 0,022 kg
€4.89 * €6.99 * (30.04% Saved)
Content: 24 cm² (€0.20 * / 1 cm²)
€4.28*
€69.98*
13403 Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x1mm
€8.44*
13409 Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1,5mm
€4.68*
13412 Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x0,5mm
€4.18*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)120 x 20 x 1mm
Thermal Conductivity (ASTM D5470)6.2 W/mK (±10%)
Hardness (ASTM D412)50 (Shore 00) (±15)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)1×10¹³ Ohm-m
Dielectric Breakdown Voltage (ASTM D149)6 KV/mm (±10%)
Density (ASTM D792)3.1 g/cm³ (±10%)
Elongation (ASTM D412)50%
Flame Rating (UL 94)V-0
Colorblue
€0.98 *
€1.19 *
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 120x20x0,5mm
Content 24 cm² (€0.17 * / 1 cm²)
€4.18 * €5.99 *
27%
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x2mm
Content 16 cm² (€0.32 * / 1 cm²)
€5.08 * €6.99 *
42%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
Content 24 cm² (€0.29 * / 1 cm²)
€6.99 * €11.98 *
43%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1mm
Content 24 cm² (€0.24 * / 1 cm²)
€5.68 * €9.98 *
43%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x0,5mm
Content 24 cm² (€0.19 * / 1 cm²)
€4.58 * €7.98 *
38%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88 *
20%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x0,5mm
Content 100 cm² (€0.10 * / 1 cm²)
€9.50 * €11.86 *
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 *
37%
WÄM Alphacool Apex Soft Wärmeleitpad 14W/mk 100x100x1mm
Alphacool Apex Soft Thermal Pad 14W/mk 100x100x1mm
Content 100 cm² (€0.44 * / 1 cm²)
€44.08 * €69.98 *
33%
€5.99 * €8.98 *
43%
€3.97 * €6.99 *
21%
€33.97 * €42.98 *
47%
WÄM Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 120x20x1mm PHT EOL
Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x1mm
Content 24 cm² (€0.15 * / 1 cm²)
€3.68 * €6.99 *
Alphacool GPU RAM Copper Heatsinks 6.5x6.5mm - 10 pcs.
Content 10 Stück (€1.00 * / 1 Stück)
