Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x1mm
  • 13403
  • 4250197134033
  • 0,047 kg
€8.44 * €16.81 * (49.79% Saved)
Content: 100 cm² (€0.08 * / 1 cm²)
€4.28*
€69.98*
13405 Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88*
13409 Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1,5mm
€4.68*
13413 Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
€4.89*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)100 x 100 x 1mm
Thermal Conductivity (ASTM D5470)6.2 W/mK (±10%)
Hardness (ASTM D412)50 (Shore 00) (±15)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)1×10¹³ Ohm-m
Dielectric Breakdown Voltage (ASTM D149)6 KV/mm (±10%)
Density (ASTM D792)3.1 g/cm³ (±10%)
Elongation (ASTM D412)50%
Flame Rating (UL 94)V-0
Colorblue
€0.98 *
€1.19 *
€12.88 *
20%
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 100x100x1,5mm
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x1,5mm
Content 100 cm² (€0.17 * / 1 cm²)
€17.41 * €21.77 *
€1.98 * €2.69 *
€2.58 *
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 120x20x0,5mm
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x0,5mm
Content 24 cm² (€0.17 * / 1 cm²)
€4.18 * €5.99 *
45%
Content 100 cm² (€0.18 * / 1 cm²)
€17.98 * €32.97 *
Alphacool y-splitter aRGB 3-pin to 3x 3-pin 30cm
Content 30 Zentimeter (€16.57 * / 100 Zentimeter)
€4.97 *
33%
€5.99 * €8.98 *
€5.78 *
62%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 100x100x0,5mm
Content 100 cm² (€0.05 * / 1 cm²)
€4.88 * €12.98 *
€27.98 *
€6.49 * €8.98 *
WAGZ Alphacool GPU Terminal flat straight - Acetal
17%
Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x1,5mm
Content 24 cm² (€0.15 * / 1 cm²)
€3.68 * €4.97 *
€11.98 *
€38.98 *
€1.78 *
