  • 11641
  • 4250197116411
  • 0,428 kg
€9.98 * €11.98 * (16.69% Saved)
S13 Alphacool Ice Tube 13/10mm PETG HardTube 80cm - Set of 4 (320cm)
€23.98*
SZ Alphacool Acrylic Tube Double Bending Tool 12-14mm and 16mm - Black
€17.98*
SZ Alphacool Eiskoffer Professional - bending & measuring kit
€262.98*
WZS Alphacool Eistools Modding Cutter - replacement blades set of 3
€9.98*
Anyone who has already worked with PETG tubes or other hard tubes will know the problem: when... more
Anyone who has already worked with PETG tubes or other hard tubes will know the problem: when sawing off the tubes, the ends are often unclean and uneven, which makes further processing much more difficult. This is now over! With the Eistools Modding Cutter, Alphacool is bringing a versatile product onto the market with which you can cut your hard tubes cleanly without much effort. And a lot more!
Stop sawing!
The familiar process remains the same: heat up the hard tube, cut it to the desired length, and you're done! Alphacool isn't reinventing the wheel here, but it is improving the results many times over. The whole thing works just as well with conventional PVC hoses, of course.
What's the point of the angle?
The greatest feature of our new tool is probably the use of different angles on the pliers. These are particularly used in other parts of the PC. If you have ever modded a PC, you will know what to expect: For example, parts of the PC have to be covered up, or the cable strips have to run at a very specific angle. Exact angles are often a must here!
In case your blade gets blunt from all the screwing and cutting, we have of course also made provisions. You can find replacement blades for your modding cutter under item number 1015313.
62%
hose cutter aluminum replacement blade 3-19mm
€0.99 * €2.59 *
WZS Alphacool Eistools Modding Cutter - Ersatzklingen 3er Set
Content 3 Stück (€3.33 * / 1 Stück)
Alphacool Eiszapfen 14mm HardTube screw-on nozzle G1/4 - Deep Black Sixpack
€34.98 *
€26.98 *
€1.78 *
Delivery date: in 2 - 3 weeks
€37.98 *
€25.98 *
