Alphacool NexXxoS HPE-45 Full Copper 420mm Radiator
- Article no.: 14442
- EAN: 4250197144421
- Weight: 1,8 kg
Connection options & mounting
Safety first
Patented screw plugs
1x Alphacool NexXxoS HPE-45 Full Copper 420mm Radiator, black
12x M3x5 case mounting screws
12x M3x30 fan screws
4x screw plugs
1x Allen key
1x plug tool
| Technical data radiator | |
| L x W x H | 455.5 x 144 x 45 mm (±3 %) |
| Quantity of cooling channels | 32 |
| Material threads | brass |
| Threads | 4x G 1/4 IN/OUT & 1x Fill-/Drainport G 1/4 (max. 5 mm thread length) |
| Possible fan size | 140 mm |
| Possible fan assembly | 3x one-sided / 6x both-sided |
| Pressure tested | 0.8 bar |
| Fin density | 16 FPI |
| Weight | 1533 g |
| Color | black |
Warranty: 10 years
