Alphacool NexXxoS HPE-45 Full Copper 280mm Radiator
  • 14441
  • 4250197144414
  • 1,368 kg
  • 10
€125.98 *
15379 Alphacool Eisbecher Aurora D5 Acetal/Glas - 250mm
€109.98*
€16.99*
€14.98*
14466 Alphacool Filling bottle Core 500ml
€5.99*
13058 Alphacool Core XP³ Acetal
€31.98*
For more than a decade, Alphacool has dominated the market with the NexXxoS Full Copper radiator... more
Connection options & mounting
Safety first
Patented screw plugs
Technical data radiator
L x W x H314.5 x 144 x 45 mm (±3 %)
Quantity of cooling channels32
Material threadsbrass
Threads4x G 1/4 IN/OUT & 1x Fill-/Drainport G 1/4 (max. 5 mm thread length)
Possible fan size140 mm
Possible fan assembly2x one-sided / 4x both-sided
Thread size fan mountingM3
Pressure tested0.8 bar
Fin density16 FPI
Weight1131 g
Warranty: 10 years
RAD Alphacool NexXxoS HPE-30 Full Copper 140mm Radiator
€89.98 *
Delivery date: in 5 - 6 weeks
€37.98 *
