Alphacool NexXxoS HPE-30 Full Copper 120mm Radiator
- Article no.: 14468
- EAN: 4250197144681
- Weight: 0,544 kg
*1For more than a decade, Alphacool has dominated the market with the NexXxoS Full Copper radiator series. Our extensive portfolio of radiator variants is unique in the world. Just like our manufacturing process, which allows us to produce all water-carrying parts and the cooling fins out of pure copper. As a result, the NexXxoS series offers the highest thermal conductivity of any radiator on the market. Thanks to their exceptional performance, the radiators can easily dissipate even extremely high waste heat and have become essential in many areas of the cooling industry.
Connection options & mounting
Safety first
Patented screw plugs
| Technical data radiator | |
| L x W x H | 151.5 x 124 x 30 mm (±3 %) |
| Quantity of cooling channels | 14 |
| Material threads | brass |
| Threads | 4x G 1/4 IN/OUT & 1x Fill-/Drainport G 1/4 (max. 5 mm thread length) |
| Possible fan size | 120 mm |
| Possible fan assembly | 1x one-sided / 2x both-sided |
| Pressure tested | 0.8 bar |
| Fin density | 18 FPI |
| Weight | 420 g |
| Color | black |
Warranty: 10 years
