Alphacool NexXxoS HPE-30 Full Copper 280mm Radiator
  • 14378
  • 4250197143783
  • 0,938 kg
  • 10
€104.98 *
ANS Alphacool Eiszapfen 13mm HardTube screw-on nozzle G1/4 - Chrome
€6.98*
€25.98*
ANS Alphacool Eiszapfen 13mm HardTube screw-on nozzle 90° rotatable G1/4 - Chrome
€9.98*
13306 Alphacool VPP Apex Pump - G1/4 inner thread including Eisdecke D5 - Acryl V.3
€83.98*
15393 Alphacool Core 100 Aurora reservoir D5/VPP Acetal/Acryl
€51.98*
For more than a decade, Alphacool has dominated the market with the NexXxoS Full Copper radiator... more
Connection options & mounting
Safety first
Patented screw plugs
L x W x H314.5 x 144 x 30 mm (±3 %)
Quantity of cooling channels16
Material threadsbrass
Threads4x G 1/4 IN/OUT & 1x Fill-/Drainport G 1/4 (max. 5 mm thread length)
Possible fan size140 mm
Possible fan assembly2x one-sided / 4x both-sided
Thread size fan mountingM3
Pressure tested0.8 bar
Fin density18 FPI
Weight724 g
Warranty: 10 years
RAD Alphacool NexXxoS HPE-30 Full Copper 140mm Radiator
€89.98 *
