Alphacool Eiszapfen 13mm HardTube screw-on nozzle 90° rotatable G1/4 - Chrome
- Article no.: 17392
- EAN: 4250197173926
- Weight: 0,074 kg
Version: 90° screw-on nozzle 13mm
This connector has a 1/4" thread on one side and is therefore compatible with 95% of all components. The other side is suitable for a 13mm acrylic and brass tube. In the middle, this connector is angled at 90° to avoid complicated hose routes. For maximum flexibility, the side with the thread can be rotated.
- Material: Brass
- Color: Chrome
dimension
- Length: 42.5mm
- Width: 21mm
Scope of delivery
- 1x Alphacool Eiszapfen 13mm HardTube screw-on nozzle 90° rotatable G1/4 for acrylic brass tubes - Chrome
Here you will find an interactive overview of all Alphacool connections.
