Alphacool Eiszapfen 16mm HardTube screw-on nozzle G1/4 - Chrome
- Article no.: 17265
- EAN: 4250197172653
- Weight: 0,045 kg
*1Alphacool's Eiszapfen connection series is the high-end version of the proven connections!
Design: HardTube screw-on nozzle 16mm
This connection has a 1/4" external thread on one side. HardTubes with an external diameter of 16mm can be screwed on the other side.
Technical details:
- Material: Brass
- Color: Chrome
Dimension:
- Diameter: 21mm
- Height: 18mm
- 1x Alphacool Eiszapfen 16mm HardTube screw-on nozzle G1/4 for acrylic brass tubes - Chrome
