Alphacool Core Geforce RTX 5090 Solid + AMP with backplate
- Article no.: 14730
- EAN: 4250197147309
- Weight: 1,88 kg
- Zotac Gaming GeForce RTX™ 5090 AMP Extreme Infinity (ZT-B50900B-10P)
- Zotac Gaming GeForce RTX™ 5090 Solid (ZT-B50900D-10P)
- Zotac Gaming GeForce RTX™ 5090 Solid OC (ZT-B50900J-10P)
| Technical data cooler | |
| Dimensions total (L x W x H) | 234,00 x 150,53 x 34,10mm |
| Material terminal | Acetal |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 11 |
| Color | transparent |
| Dimensions (L x W x H) | 234,00 x 122,00 x 6mm |
| Thick backplate without spacers | 3mm |
| Material | Aluminium |
