Alphacool Core Geforce RTX 5090 ROG Astral with backplate
  • 10270
  • 4250197102704
  • 2,004 kg
€229.98 *
€19.98*
€37.98*
€35.98*
€125.98*
- Asus ROG Astral GeForce RTX™ 5090 32GB GDDR7 (90YV0LW1-M0NA00)
- Asus ROG Astral GeForce RTX™ 5090 32GB GDDR7 OC Edition (90YV0LW0-M0NA00)
- Asus ROG Astral LC GeForce RTX™ 5090 32GB GDDR7 (90YV0LW3-M0NA00)
- Asus ROG Astral LC GeForce RTX™ 5090 32GB GDDR7 OC Edition (90YV0LW2-M0NA00)
Technical data cooler
Dimensions total (L x W x H)260,25 x 160,90 x 34,32mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs12
Colortransparent
Technical data backplate
Dimensions (L x W x H)260,25 x 132,50 x 6mm
Thick backplate without spacers3mm
MaterialAluminium
€34.98 *
€39.98 *
€28.98 *
