Alphacool GPU 180° Terminal
  • 13763
  • 4250197137638
  • 0,369 kg
€65.98 *
€35.98*
13429 Alphacool Eisblock Aurora Acryl GPX-N RTX 4090 Reference with Backplate
€49.98*
13441 Alphacool Eisblock Aurora Acryl GPX-N RTX 4080 Reference Design with Backplate
€49.98*
The Alphacool GPU 180° terminal allows flexible connection options for GPU coolers. Perfect for... more
The Alphacool GPU 180° terminal allows flexible connection options for GPU coolers. Perfect for extensive modding projects or for systems with limited space. The elegant design is perfected by a magnetic cover.
Flexible connections
The Alphacool GPU 180° terminal replaces the standard terminal of the GPU cooler. It positions the connections above the backplate, significantly reducing the depth of the cooling block. With three possible connection options for each input and output - top, side and rear - the terminal offers maximum flexibility.
All Alphacool Eisblock Aurora coolers
All Alphacool Core coolers for the RTX 5XXX and AMD RX 9XXX series
Attention
The terminal is not compatible with the Alphacool Core coolers of the RTX 4XXX and RX 7XXX series.
Note: Please follow the manual for the correct flow direction of the water.
Dimensions (L x W x H)84.00 x 31.00 x 61.60mm
Material (water-bearing elements)Chrome-plated brass, acetal
Material magnetic cover (not water-bearing)Aluminum
Threads3x G1/4“ In | 3x G1/4“ Out
Pressure tested0.8 bar
Max working temperature60°C
Weight320g
Colorblack, chrome
Warranty: 2 years
Alphacool NexXxoS GPX accessory pack 3W/mk
Content 108 cm² (€0.04 * / 1 cm²)
€3.97 *
WAGZ Alphacool Eisblock GPX Aurora Abstandhalter M2 2,5mm
Alphacool Eisblock GPX Aurora spacer M2 2.5mm
Content 10 Stück (€0.30 * / 1 Stück)
€2.98 *
