Alphacool Apex Grip offset 16mm OT/IT G1/4 rotatable chrome
  • 14892
  • 4250197148924
  • 0,068 kg
  • 5
S16 Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 60cm - Set of 4 (240cm)
€19.98*
€16.98*
€279.98*
€178.98*
The offset fittings allow for precise alignment of the connection point. Both the offset section and the threaded head can be rotated through 360°, making it possible to position the connection exactly where needed for clean and efficient tubing or hard tube routing.
Technical Data
Dimensions (LxWxH)39,50 x 23,50 x 24,10mm
Diameter19,40mm
MaterialBrass
Material Grip SurfaceSilicone
Threads2x G1/4
Thread Length5mm
Colorchrome
Warranty: 5 years
€33.98 *
€38.98 *
Content 240 Zentimeter (€7.49 * / 100 Zentimeter)
€25.98 *
