Alphacool Apex Grip offset 27mm 2x 90° OT/IT G1/4 rotatable chrome
- Article no.: 14894
- EAN: 4250197148948
- Weight: 0,136 kg
The offset fittings allow for precise alignment of the connection point. Both the offset section and the threaded head can be rotated through 360°, making it possible to position the connection exactly where needed for clean and efficient tubing or hard tube routing.
| Technical Data | |
| Dimensions (LxWxH) | 50,50 x 23,50 x 32,25mm |
| Diameter | 19,40mm |
| Material | Brass |
| Material Grip Surface | Silicone |
| Threads | 2x G1/4 |
| Thread Length | 5mm |
| Color | chrome |
Warranty: 5 years
