Alphacool Apex Grip extension 20mm OT/IT G1/4 chrome
  • 14898
  • 4250197148986
  • 0,051 kg
  • 5
€5.48 *
S16 Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 60cm - Set of 4 (240cm)
€19.98*
€16.98*
€279.98*
€178.98*
Technical Data
Height25,50mm
Diameter20,10mm
MaterialBrass
Material Grip SurfaceSilicone
Threads2x G1/4
Thread Length5mm
Colorchrome
Warranty: 5 years
