Alphacool Apex Grip double nipple OT/OT rotary G1/4 chrome
ANF Alphacool Apex Grip Doppelnippel AG/AG drehbar G1/4 chrom
  • 14918
  • 4250197149181
  • 0,047 kg
  • 5
€4.98 *
18439 Alphacool HardTube 13/10mm Acryl clear 60cm - 4pcs
€15.98*
€279.98*
€178.98*
S13 Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Black 3m (9.8ft) Retailbox 300cm
€15.98*
Technical Data
Height28,00mm
Diameter19,40mm
MaterialBrass
Material Grip SurfaceSilicone
Threads2x G1/4
Thread Length5mm
Colorchrome
Warranty: 5 years
