Alphacool Apex Grip sleeve 16mm IT/IT G1/4 chrome
ANF Alphacool Apex Grip Muffe 16mm IG/IG G1/4 chrom
  • 14946
  • 4250197149464
  • 0,037 kg
  • 5
€4.98 *
S16 Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 60cm - Set of 4 (240cm)
€19.98*
€16.98*
€279.98*
€178.98*
Technical Data
Height16,80mm
Diameter19,40mm
MaterialBrass
Material Grip SurfaceSilicone
Threads2x G1/4
Colorchrome
Warranty: 5 years
Content 240 Zentimeter (€7.49 * / 100 Zentimeter)
