Alphacool Apex Grip SoftTube fitting 16/10mm G1/4 chrome Set 6 pcs
  • 14924
  • 4250197149242
  • 0,18 kg
  • 5
€42.98 *
€16.98*
€279.98*
€178.98*
14158 Alphacool NexXxoS ST30 Full Copper 360mm radiator
€66.98*
Technical Data
Height18,50mm
Diameter23,50mm
MaterialBrass
Material Grip SurfaceSilicone
ThreadsG1/4
Thread Length5mm
Softtube compatibility16mm outer diameter (OD); 10mm inner diameter (ID)
Colorchrome
Warranty: 5 years
Alphacool hose AlphaTube HF 16/10 (3/8"ID) - UV White 3m (9.8ft) Retailbox 300cm
€38.98 *
