B-Ware Alphacool Core 70 Tube Reservoir D5 mit VPP Apex PWM Pumpe
AGB B-Ware Alphacool Core 70 Tube Reservoir D5 mit VPP Apex PWM Pumpe
  • 5100326
  • 4070201000563
  • 0 kg
€159.98 * €199.98 * (20% Saved)
This is a B-stock item.   The item may have production-related visual... more
The item may have production-related visual imperfections. These may include light scratches in the glass, small air bubbles, or visible adhesive residue.
The imperfections may vary from item to item and do not affect functionality.
The accessories are fully included.
For technical details, please refer to item 1023976.
Gebrauchte Ware
WAC Alphacool Core 1 Carbon
€125.98 *
Alphacool fan radiator screw M3 x 15 mm - 4 pieces
€3.48 *
