Alphacool Apex Grip adapter 90° OT/IT G1/4 rotatable chrome Set 4 pcs
  • 14933
  • 4250197149334
  • 0,243 kg
  • 5
€45.98 *
18439 Alphacool HardTube 13/10mm Acryl clear 60cm - 4pcs
€15.98*
€279.98*
€178.98*
S13 Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Black 3m (9.8ft) Retailbox 300cm
€15.98*
Technical Data
Dimensions (HxD)40,10x15,40mm
Diameter19,40mm
MaterialBrass
Material Grip SurfaceSilicone
ThreadsG1/4
Thread Length5mm
Colorchrome
Warranty: 5 years
€33.98 *
52%
and Conditions Alphacool Cape Corp Coolplex HF Metal 15 - Chrome
€19.99 * €41.39 *
