Alphacool Apex Grip HardTube fitting 16mm G1/4 chrome Set 6 pcs
- Article no.: 14930
- EAN: 4250197149303
- Weight: 0,213 kg
| Technical Data | |
| Height | 22,30mm |
| Diameter | 25,00mm |
| Material | Brass |
| Material Grip Surface | Silicone |
| Threads | G1/4 |
| Thread Length | 5mm |
| Hardtube compatibility | 16mm outer diameter (OD) |
| Color | chrome |
Warranty: 5 years
