Alphacool Apex Grip adapter 90° OT/IT G1/4 rotatable black Set 4 pcs
  • 14932
  • 4250197149327
  • 0,243 kg
  • 5
€45.98 *
Technical Data
Dimensions (HxD)40,10x15,40mm
Diameter19,40mm
MaterialBrass
Material Grip SurfaceSilicone
ThreadsG1/4
Thread Length5mm
Warranty: 5 years
Alphacool fan radiator screw M3 x 15 mm - 4 pieces
€3.48 *
