Alphacool Apex Grip adapter 90° OT/IT G1/4 rotatable black
- Article no.: 14807
- EAN: 4250197148078
- Weight: 0,068 kg
| Technical Data | |
| Dimensions (HxD) | 40,10x15,40mm |
| Diameter | 19,40mm |
| Material | Brass |
| Material Grip Surface | Silicone |
| Threads | G1/4 |
| Thread Length | 5mm |
| Color | black |
Warranty: 5 years
