Alphacool Apex Grip extension 20mm OT/IT G1/4 black
- Article no.: 14812
- EAN: 4250197148122
- Weight: 0,051 kg
| Technical Data | |
| Height | 25,50mm |
| Diameter | 20,10mm |
| Material | Brass |
| Material Grip Surface | Silicone |
| Threads | 2x G1/4 |
| Thread Length | 5mm |
| Color | black |
Warranty: 5 years
