Alphacool Eiszapfen filter G1/4 inner thread - Acryl
  • 29121
  • 4250197136525
  • 0,015 kg
Alphacool’s Eiszapfen series is forward-looking and distinguishes itself through its exceptional... more
Alphacool’s Eiszapfen series is forward-looking and distinguishes itself through its exceptional design and high flow rate.
The Alphacool Eiszapfen acryl filter is ideal for water cooling systems with microstructure coolers. The filter prevents the microstructure coolers from becoming clogged, since these coolers are often difficult to clean manually due to their small size.
The filter is designed in such a way that resistance through the filter screen is minimal. The flow rate value of the filter for tubes with an inner diameter of 8mm is 50% higher. For 10mm inner diameter tubing, the measurable increase in flow rate is 30%. The filter is the perfect choice for high-flow systems, as a flow rate reduction only occurs when more than 30% or 50% of the filter is added (depending on the inner tube diameter).
This filter is available in three different colours: chrome, deep black and now also in acryl.
Technical Specifications
L x D20 x 25 mm
Materialacrylic
Filterstainless steel fibre microfilter
Flow rate reduction only after very clogged(30 % to 50 %)
Connector thread2x G 1/4
€1.98 *
