Alphacool Apex Grip adapter 45° OT/IT G1/4 rotatable black
  • 14808
  • 4250197148085
  • 0,054 kg
  • 5
S16 Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 60cm - Set of 4 (240cm)
€19.98*
€16.98*
€279.98*
€178.98*
Technical Data
Height31,10mm
Diameter19,40mm
MaterialBrass
Material Grip SurfaceSilicone
ThreadsG1/4
Thread Length5mm
Warranty: 5 years
