Alphacool Apex Grip SoftTube fitting 13/10mm G1/4 black Set 6 pcs
- Article no.: 14920
- EAN: 4250197149204
- Weight: 0,159 kg
*1The Alphacool Apex Grip fittings are built around a modular system that allows for flexible and customized connection solutions in modern custom water-cooling setups. Combined with the refined and distinctive Apex design, high-quality workmanship, and user-friendly handling, the series is an ideal choice for demanding systems.
| Technical Data | |
| Height | 18,50mm |
| Diameter | 20,00mm |
| Material | Brass |
| Material Grip Surface | Silicone |
| Threads | G1/4 |
| Thread Length | 5mm |
| Softtube compatibility | 13mm outer diameter (OD); 10mm inner diameter (ID) |
| Color | black |
Warranty: 5 years
