Alphacool Eisblock Aurora Acryl GPX-N RTX 4090 Suprim with Backplate
  • 13459
  • 4250197134590
  • 2,361 kg
€49.98 * €159.98 * (68.76% Saved)
17396 Alphacool HF quick release connector kit G1/4 - black
€8.98*
11679 Alphacool Eisbaer Aurora LT360 CPU AIO Digital RGB
€176.98*
ROH Alphacool Eisbaer TPV Extension Set 90° (hose and connections)
€19.98*
€14.98*
14466 Alphacool Filling bottle Core 500ml
€5.99*
€6.98*
The next generation - The Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics... more
The next generation - The Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
Thermal paste & thermal pads
- MSI GeForce RTX 4090 Gaming Trio 24G, 24GB GDDR6X
- MSI GeForce RTX 4090 Gaming X Trio 24G, 24GB GDDR6X (V510-006R)
- MSI GeForce RTX 4090 Suprim Liquid X 24G, 24GB GDDR6X
- MSI GeForce RTX 4090 Suprim X 24G, 24GB GDDR6X (V510-001R)
Technical data cooler
L x W x H266.6 x 160 x 34.6 mm
Material cooler topacrylic
Max working temperature60 °C
Pressure tested0.8 bar
Threads4 x G 1/4
Thickness cooling fins0.4 mm
Distance cooling fins0.4 mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5 V
Number of digital aRGB LEDs12
Technical data backplate
L x W x H266.6 x 127.25 x 6 mm
Materialaluminium
Delivery date: in 5 - 6 weeks
