Alphacool Apex Grip SoftTube fitting 13/10mm G1/4 black
  • 14797
  • 4250197147972
  • 0,037 kg
  • 5
€279.98*
€178.98*
14158 Alphacool NexXxoS ST30 Full Copper 360mm radiator
€66.98*
S13 Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Black 3m (9.8ft) Retailbox 300cm
€15.98*
Technical Data
Height18,50mm
Diameter20,00mm
MaterialBrass
Material Grip SurfaceSilicone
ThreadsG1/4
Thread Length5mm
Softtube compatibility13mm outer diameter (OD); 10mm inner diameter (ID)
Warranty: 5 years
52%
Hint!
€4.80 * €9.98 *
WAK Alphacool ES AI PRO R9700 1-Slot-Design
€324.98 *
Alphacool y-splitter aRGB 3-pin to 2x 3-pin 60cm
€4.68 *
€4.38 *
€20.98 *
