Alphacool Apex Grip offset 27mm 2x 90° OT/IT G1/4 rotatable black
  • 14814
  • 4250197148146
  • 0,141 kg
  • 5
€29.98 *
S16 Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 60cm - Set of 4 (240cm)
€19.98*
€16.98*
€279.98*
€178.98*
The offset fittings allow for precise alignment of the connection point. Both the offset section and the threaded head can be rotated through 360°, making it possible to position the connection exactly where needed for clean and efficient tubing or hard tube routing.
Technical Data
Dimensions (LxWxH)50,50 x 23,50 x 32,25mm
Diameter19,40mm
MaterialBrass
Material Grip SurfaceSilicone
Threads2x G1/4
Thread Length5mm
Warranty: 5 years
€1.78 *
€1.98 *
Alphacool HardTube 16/13mm 90° acrylic (PMMA) 20/40cm
Content 60 Zentimeter (€21.63 * / 100 Zentimeter)
