Alphacool Apex Grip SoftTube fitting 16/10mm G1/4 black
  • 14798
  • 4250197147989
  • 0,041 kg
  • 5
€8.48 *
€16.98*
€279.98*
€178.98*
14158 Alphacool NexXxoS ST30 Full Copper 360mm radiator
€66.98*
Technical Data
Height18,50mm
Diameter23,50mm
MaterialBrass
Material Grip SurfaceSilicone
ThreadsG1/4
Thread Length5mm
Softtube compatibility16mm outer diameter (OD); 10mm inner diameter (ID)
Warranty: 5 years
17%
€6.99 *
