Alphacool Apex Grip HardTube fitting 16mm G1/4 black
  • 14796
  • 4250197147965
  • 0,046 kg
  • 5
€9.48 *
S16 Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 60cm - Set of 4 (240cm)
€19.98*
€279.98*
€178.98*
14158 Alphacool NexXxoS ST30 Full Copper 360mm radiator
€66.98*
Technical Data
Height22,30mm
Diameter25,00mm
MaterialBrass
Material Grip SurfaceSilicone
ThreadsG1/4
Thread Length5mm
Hardtube compatibility16mm outer diameter (OD)
Warranty: 5 years
